Hi guys.
I'm looking to buy a gaming laptop for an absolute hard capped amount of £700.
Here's an example of a laptop I found within my price range:
CPU: Intel® Core™ i7-2670QM processor
Operating System: Genuine Windows® 7 Home Premium 64 bit
Clock Frequency: 3.1
Memory size: 8 GB
Total RAM slots: 2
Used RAM slots: 2
Hard disk capacity: 750 GB
Screen size: 39,6 cm (15,6")
Resolution: 1366x768 pixels
Screen Type: non-glare display
LED Backlight: Yes
NVIDIA® GeForce® GT555M DirectX® 11 graphics card featuring 2048 MB memory and digital HDMI audio/video output NVIDIA® Optimus™ technology
Multi-standard DVD/CD writer* featuring DVD-RAM and dual layer support
High-definition audio with 2 loudspeakers and 1 subwoofer – Dolby Home Theater® v4-certified
Biometric fingerprint sensor
Intel® Wireless Display (WiDi)
Integrated 1.3 MP webcam with microphone
Multi-card reader for SD, SDHC, SDXC, MMC, MS and MS-Pro memory cards (memory cards not supplied)
Multi-media management using sensor keys
MultiTOUCHpad
<Removed> Solid Keyboard
Battery
Battery cells: 8
Interfaces & Connections
Multi-card reader for SD, SDHC, SDXC, MMC, MS & MS Pro memory cards
2x USB 3.0***
2x USB 2.0
1x HDMI out
1x VGA out
1x LAN (RJ45)
Audio (The use of these connections depends on software settings):
1x Microphone
1x Line out incl. S/PDIF
Connections
Gigabit LAN network controller (10/100/1000 Mbit/s)
Intel® Centrino® Advanced-N 1030 with integrated Bluetooth 3.0
Fast wireless LAN IEEE 802.11 n-standard technology
Software (OEM Versions)
Windows® Live™ Essentials
Microsoft® Office 2010 preinstalled
Functional trial versions of Word® and Excel® are preinstalled and ready for immediate use on this computer. To be able to use all of the functions in the Office 2010 applications installed on this computer, you must purchase an Office 2010 Product Key Card or an Office 2010 package. An Internet connection is needed in order to activate the Office 2010 applications.
CyberLink Power2Go**
CyberLink YouCam
Kaspersky Internet Security 2011
Incl. 90-day free online update. (Internet connection required for activation). After 90 days, you must purchase a licence if you want to continue using the software.
In the box
<Removed> laptop
8-cell li-Ion high-performance battery
External mains adapter
Warranty card
Operating instructions
Windows® 7 Home Premium Recovery DVD
<Removed> application and support disc
Other information
Dimensions: (W x H x D): approx. 385 x 262 x 23.6-37.8 mm
Weight: approx. 2,700 g (including battery)
Warranty: 12 month warranty
Any suggestions for better?
Memory size: 8 GB
Total RAM slots: 2
Used RAM slots: 2
LED Backlight: Yes
MultiTOUCHpad
Battery
Battery cells: 8
2x USB 3.0***
2x USB 2.0
1x HDMI out
1x VGA out
1x LAN (RJ45)
1x Microphone
Connections
CyberLink YouCam
In the box
<Removed> laptop
Warranty card
Other information
