since speccing up a P67 / 2500K build for my dad ive learnt many things and if i hadnt I would have bought all the wrong stuff
namely...
1. You need P67 chipset to be able to overclock the 2500k
2. SandyBridge chipset only allows for 1333mhz RAM speeds by default (without overclocking) some p67 boards seem to be advertised as 1600Mhz without the (OC) next to it so I thought it meant 1600Mhz would run @ 1600Mhz without need to overclock...maybe they are advertised wrong...do any boards support 1600Mhz without overclocking? if not..why do they make 1600Mhz ram?
3. your memory has to be 1.5v to work on SandyBridge board.
is there anything else I should know before I **** up?
thanks
namely...
thanks
