Anything I could upgrade?
Permabanned
15 Jan 2006
Got the Christmas pressies for everyone and I have £997 left around doing nothing, and I'm due to be paid again in under a week. So I thought I may aswell treat myself seeing as it is Christmas.
So I was wondering whether there was anything I could upgrade with my PC?
Tbh I don't feel it always performs the best with games, particularly Battlefield 2 and FEAR. Don't want to spend a huge amount but a fair bit, and I thought you guys could give me some advice.
Spec,
MSI K8N Neo4 Platinum
x2 3800
2GB Corsair Value RAM
x1800xt 512mb
Thanks.
Is the CPU overclocked? Depending on how much of the money you want to spend you could do a full overhaul or go part-way with either a new CPU, motherboard and Ram (£400ish) or alternatively go for a new graphics card like the 8800gts (£300ish).
Sell these:
x2 3800
Should get at least £150
Then you could go for:
Intel E6300
Gigabyte DS3
2GB GeIL 6400C4 DDR2 Kit
Belinea 2225S1W 22" Widescreen LCD Monitor
Slap on a decent third party CPU cooler and clock like crazy
Also possibility to sell your X1800XT for ~£100 and replace with a X1900/X1950 or 8800GTS?
iGiDK said:
Sell these:
x2 3800
Try closer to £250, DDR is still fetching a fair bit 2nd hand.
@IwantanewPC - Do you overclock?
2 options really:
you could consider an overhaul and opt for a Core2 duo E6300/E6600, 2gb Geil ULL, an Asus P5B Deluxe + an 8800GTS.
or for ease, you could just go for an 8800GTS, and maybe clock you're CPU a bit to remove the bottleneck.
I don't overclock at all no.
Was thinking of selling my Motherboard, CPU, Graphics Card and RAM and then upgrading to the latest shizzle as has been suggested. I'll need a much better PSU if I plan to go that route though.
You guys think it's worth it then in the long run?
