Anything to be gained from a K&N filter?
31 Jul 2004
Surrey
I'm slowly getting round to a light breathing on my now out of warranty focus ST and I'm pondering a K&N air filter, I may possibly go with an induction kit at some point but what I want to know is is there anything to be gained from having the filter?
increased performance?
better economy? Not that I really care tbh
better engine health?
You wont see an increase in performance. Maybe a little difference in induction sound which will make you think it's got a little more umpff.
Nope, no more economical.
A K&N filter lets through more dirt than a standard filter.
It would be a negligible amount if you clean them properly (which most don't)
so a general all round no then?
I figured a "performance" part would be better?
even on my 2.8 V6 turbo vectra
im told it has zero "peak" bhp increase and just helps the engine breather a little easier at the top end.
oh and adds a nice induction noise.
i'm still buying one though. Buy one by all means, but dont expect miracles from it.
I don't really have a problem with my car getting noisier either as long as the noise is doing something?
i normally drown out the exhaust noise with radio 4 :) (no I'm not joking)
Which would be overcome by the now audible turbo spool ;)
I used to work next to Turbosystems in Newcastle , Staffs and used to spend too much time after work looking over their many creations, many of which had K&N's as it was one of the done things..... imo the K&N made quite a nice addition to the spooling sounds of the RST & Cosworths. :)
my car came with one. i swapped it for a pipercross when i could see holes through the K&N, some about 1mm across
its meant ot be a filter
id stick with the oem part personally
My 540i had a K&NH filter in it when I got it. One of the first things I did was take it out and replace it with an OEM one.
I don't trust K&N filters. The minimum filtered paticulate size just isn't small enough for my liking.
It depends if you're referring to the K&N panel filter or the cone induction kit - i'm assuming the former?
There's very very little to be gained from those, I doubt the sound would even change much if at all
Pretty negative responses here, personally I'd investigate how restrictive the OEM filter might be.
On most Impreza's for example said filter is rather restrictive and a new filter really opens up the throat.
I have one on the MR2 and clean it regularly. Over the standard airbox (which is absolutely bloody ridiculous with the multitude of auxillary chambers and stupid detours for the airflow) it offers MUCH better sound and increased throttle response. I cleaned it out the other day and I swear I got around 25-30 more horsepowahz too.
