Anything wrong with these stats?
19 Oct 2002
Woolyback Country
View Broadband Link Statistics
WARNING
To use this page to customize the features of your*BT2700HGV, you must have JavaScript enabled. JavaScript is currently disabled in your browser or by the security software on your PC. To enable JavaScript in your browser, please read the documentation associated with your browser. To enable JavaScript disabled by the security software on your PC, please read the documentation for that software.
Transmit and Receive Data
IP Bytes
Packets
Errors Transmit: 2702484296
147533621
0 Receive: 2001461534
164890078
0
Data Errors
Statistics
Collected for 13 days 20:38:32
Since ResetCurrent 24-Hour IntervalCurrent 15-Minute IntervalTime Since Last EventATM Cell Header Errors:997675910:01:41
ATM Loss of Cell Delineation:492826410:01:41
DSL Link Retrains:0000:00:00
DSL Training Errors:10013 days 20:37:35
DSL Training Timeouts:0000:00:00
DSL Loss of Framing Failures:0000:00:00
DSL Loss of Signal Failures:0000:00:00
DSL Loss of Power Failures:0000:00:00
DSL Loss of Margin Failures:0000:00:00
DSL Cumulative Errored Seconds:418845710:01:41
DSL Severely Errored Seconds:1216017:41:21
DSL Corrected Blocks:103060677920:00:45
DSL Uncorrected Blocks:1097083410:01:41
ISP Connection Establishment:111
0:01:26
DSL Connection Details DSL Line (Wire Pair): Line 1 (inner pair) Protocol: G.DMT Annex A Downstream Rate: 2272 kbps Upstream Rate: 768 kbps Channel: Interleaved Current Noise Margin: 15.0 dB (Downstream) 6.0 dB (Upstream) Current Attenuation: 59.1 dB (Downstream) 31.5 dB (Upstream) Current Output Power: 17.9 dBm (Downstream) 11.9 dBm (Upstream) DSLAM Vendor Information: Country: {0x0F} Vendor: {ALCB} Specific: {0x00} PVC Info: 0/38
Internet Connection Details Connection Type: PPPoE Username:************ Internet Address: ******** Subnet Mask: 255.255.255.255 Default Gateway: 188.39.0.10 Primary Domain Name Server: 195.74.113.58 Secondary Domain Name Server: 195.74.113.62 Domain:
Maximum Transmission Unit (MTU): 1492 Gateway Ping: Successful DNS Communication: Successful Configuration Server Post: Successful
Been trying a new router see i was hoping that the SNR would have been less by now to squeeze a bit more speed from my line
Old router was a dg834GT attenuation was 60db and synch was about 2272 but with the snr @1% this router has synch @2272 with snr untweaked @100%
high snr is good , low attenuation is good ? thats what thought anyway
my line sync @ 6304
-------------------- down up
SNR Margin 9.4 28.0 dB
Line Attenuation 31.6 19.0 dB
Why is your downstream speed fixed at 2Mbps? You have a long line but you could probably get a bit more.
Not fixed mate,this just happens to be what it synced at when i swapped from one router to the other.With my dg834 gt i was syncing anywhere up to 2848 ish(this was last year though) since then it has been all over the shop(mostly it was around 2000 synch,giving me a ip profile of 1800 ish)
I am on a long line nearly 3miles from the exchange
With tis 2 wire router i get a slightly better attn downstream of 59 compared to the gt at 60.
I was hoping that with a stable connection for 14 days i would get the 15 db snr lowered so that i may get a higher synch,but as of yet no change :(
