Will onboard sound be just as good?
Onboard sound these days is very high quality, long gone are the days of Beeep Beeep Beeep.
mmm, thats a different view to what ive been reading on the sound part of this forum - i;d love to get a definitive answer
For a average gamer without studio quality speakers/headphones etc the onboard is fine.
If your main use is audio production then I can see the benefit of a dedicated audio card (but not a crap £20 version) I just posted my X-fi Xtrememusic today after selling it on the MM, I havent used it since putting this Gigabyte board into my system and I dont miss it.
The X-fi Xtrememusic was a proper sound card unlike the cheaper X-fi cards that dont have the same processor such as the xtreme audio.
how would you compare the quality from your card to the onboard?![]()
I also have the HX520W, not HX620W. Will this be enough power?
Cheers. I may change my mind though because every time I turn off my PC, the computer fans keep running and I have to manually turn off the PSU. =/Just, you are lucky that the HX520 was a quality PSU.
I'm sure there is no such feature, the PSU and all the fans and mobo lights continue to work until I eventually turn it off from the back of the PSU.Is there some sort of cool down feature on the motherboard? where it still spins after power off to cool the parts, some PSU's do this with their internal fan.
Sorry to butt in but this sound card thing is of interest as i currently use onboard sound and was considering a dedicated sound card myself..BUT not for better sound quality as my onboard sounds awseome...but for the reported increase in frame rates that some say you get as the card relieves the cpu of this task.
Is this correct? if so then sound quality isn't the only reason why people should consider upgrade.
I do have an unused creative soundblaster X-FI extreme gamer card and quoting from what it says on the box "The worlds most powerful audio processor can boost game performance by upto 15% over motherboard audio" wouldn't this be a good reason in itself to upgrade?
i5 2500k @4.6ghz, Asus P8Z68 Deluxe, Kingstone hyperx 8GB, Gainwood GTX580 good edition, OCZ 1000w, 1tb samsung f3 hdd.
