Anything wrong with this script? (PHP)
Hitman
25 Feb 2004
Hey,
Having some strange problems with this particular script. It doesn't load or anything, just shows a white blank page.
PHP:
<?php
	$db_host = "1";
	$db_user = "2";
	$db_pwd = "3";
	$db_name = "4";
	mysql_connect($db_host, $db_user, $db_pwd);
	mysql_select_db($db_name);
	if (!isset($_POST["submit"]))
		echo("
		<form action="" method=\"post\">
		Player ID: <input type=\"text\" name=\"playerid\"><br />
		XP Amount: <input type=\"text\" name=\"xp\"><br />
		Race: <input type=\"text\" name=\"race\"><br />
		Skill 1: <input type=\"text\" name=\"skill1\"><br />
		Skill 2: <input type=\"text\" name=\"skill2\"><br />
		Skill 3: <input type=\"text\" name=\"skill3\"><br />
		Skill 4: <input type=\"text\" name=\"skill4\"><br />
		<br />
		<input type=\"submit\" name=\"submit\" value=\"Submit\">
		</form>
		Race List<br />
		<br />
		1 => Undead Scourage<br />
		2 => Human Alliance<br />
		3 => Orcish Horde<br />
		4 => Night Elves of Kalimdor<br />
		5 => Blood Mage<br />
		6 => Shadow Hunter<br />
		7 => Warden<br />
		8 => Crypt Lord<br />
		9 => Chameloen
	else
		$playerid = $_POST["playerid"];
		$xp = $_POST["xp"];
		$race = $_POST["race"];
		$skill1 = $_POST["skill1"];
		$skill2 = $_POST["skill2"];
		$skill3 = $_POST["skill3"];
		$skill4 = $_POST["skill4"];
		mysql_query("DELETE FROM `war3users` WHERE playerid='".$playerid."' AND race='".$race."'") or die(mysql_error());
		mysql_query("INSERT INTO `war3users` (playerid, xp, race, skill1, skill2, skill3, skill4) VALUES ('".$playerid."', '".$xp."', '".race."', '".skill1."', '".skill2."', '".skill3."', '".skill4."') or die(mysql_error());
		echo("
		Ta
I've used this to do other things, such as just sending a DELETE query, which works fine. But I'm stumpted to why this one doesn't work :confused:
Would appreciate any help on this :)
Cheers.
stick
Code:
display_errors(1);
error_reporting(E_ALL);
at the top, sounds like you are getting an error with DB stuff but it's not displaying errors.
Dj_Jestar said:
stick
Code:
display_errors(1);
Done. Still loads a blank page though, showing nothing (even in the source of the page) :/
replace it all with:
Code:
<?php
phpinfo();
If that doesn't display anything, contact your host (or if a local install, reinstall webserver and php.) :)
Code:
<?php
phpinfo();
That works fine. The rest of the site is coded in PHP (including a forum, among other things) which is all running with no problems. I've used the script in the original post on 4 other pages (slightly edited), but for some reason this one just won't load at all.
Matt
place echo "Test"; just before the if statement, if that doesnt print its obviously the database connection.
Done, and again it just shows a blank page. I don't know how this could be a database issue, seeing as the user/pass/etc is all correct, and the other scripts work fine :|
Cheers anyway.
Change your connection to:
PHP:
mysql_connect($db_host, $db_user, $db_pwd) or die(mysql_error());
mysql_select_db($db_name) or die(mysql_error());
See what that comes up with
Also add an echo test at the top of the page and see if the page is actually opening.
PHP:
Added and nothing shows up. Also tried the echo at the very top and it doesn't show either. So strange :confused:
display_errors needs to be enabled via:
Code:
ini_set('display_errors', 1);
There's a syntax issue in your INSERT query:
Code:
VALUES
('".$playerid."', '".$xp."', '".[b][color=yellow]race."', '".skill1."', '".skill2."', '".skill3."', '".skill4."'[/color][/b])
Code:
Code:
VALUES
Not sure how I managed to miss that, fixed that. Added the correct display errors and still doesn't show anything.
I may just leave this, absolutly no idea why it doesn't want to load.
Cheers.
PHP:
    $db_host = "1";
    $db_user = "2";
    $db_pwd = "3";
    $db_name = "4";
        echo("
        <form action=\"\" method=\"post\">
        <br />
        </form>
        Race List<br />
        <br />
        7 => Warden<br />
        9 => Chameloen
    else
        $xp = $_POST["xp"];
        mysql_query("INSERT INTO `war3users` (playerid, xp, race, skill1, skill2, skill3, skill4) VALUES ('".$playerid."', '".$xp."', '".$race."', '".$skill1."', '".$skill2."', '".$skill3."', '".$skill4."'") or die(mysql_error());
        echo("
        Ta
2 minor changes in addition to Augmented's. You'll kick yourself :)
Beansprout said:
PHP:
 echo("...<form action=\"\" method=\"post\">...
:o :o :o
How on earth did I miss that. Cheers mate, all fixed :)
