anyway i can improve my wireless signal.
Permabanned
26 Nov 2006
guildford, surrey
I have a Linksys router i just bought from ocuk, and its all going well, just the signal is a little low, its currently at about 72% on my PS3 (which is what im trying to use it for.) Is there anyway to improve other than the obvious 'move it closer' way?
72% seems ok to me...
What is the router near? And by that, what is within 4 feet of it? :)
Its possible, that if near wireless phones, metal objects, microwaves etc that they're disrupting the signal.
72% isn't bad at all, you could get get a bigger antenna for the router or buy/make a parabolic for it but tbh if it's not impacting your ps3 connectivity then don't worry about it.
