Anyway of scaling this up for printing ?
Man of Honour
16 Mar 2005
Clevedon , Bristol
Is there a 'tool ' available that would convert an image into a scalable graphic suitable for printing i.e 300 pixels per inch
From this ;
Retain the same size, but 300ppi not the current 72 ppi
Any pointers would be great :)
If you retained the same size but change to 300dpi, that image would be printed at a little over 2cmx2cm.
You need a much larger, higher quality image for printing. 300DPI is obviously better, but size is what counts.
My knowledge is limited, but could it be turned in to a vector image? shouldn't be a problem then should it?
A vector image would solve the problem, however you'd need to draw it by hand in PS/Illustrator. There's no (good) software which will turn a raster image into vector.
inkscape is a free alternative to illustrator, if you import that image then go to path->trace bitmap
then choose colors in the bottom box, after that just keep trying to adjust the various settings while clicking update. You might need a cleaner version of the image first though.
