Broadbandplacey said:er yeah,
plug it in,
and on your left hand navigation bar,
it will appear underneath "network" (3rd one down) as a removable drive (with a little circle to the right of the text which is the safely eject button)
once youve clicked that tab all of the folders and files are in there that you should be able to view in various different ways.
hope that helps
