Currently doing a quick refresh of my system with new tubing/fluid due to installing new parts.
I'm experiencing a small leak on my DDC pump with EK XRes 140 Top.
I never used to have this in the past. I noticed this after I put the new loop together earlier today. When I saw the leak the first time round I drained everything, replaced the fitting with a new one, thinking maybe the old o-ring was damaged. I also cleaned/dried the hole and made sure the fitting was placed in quite firmly.
Alas, I'm still experiencing the same thing even after new fitting. It's not a huge leak, the above photo took 1h to get to that stage. I will probably drain my system again tomorrow and try again.
Has anyone got anything I can try to see if that will solve the issue?
