Anyway to get my Wii on my TFT?
i use that cable, works very well with Wii games but it doesnt (or the Wii cant) play VC games via the cable.
You will need a female to female vga connector (a spare VGA cable works fine for me) as well as for some reason it comes with a male :confused:
I bought a component and vga cable for my wii so have the vga cable spare if you want it? (not free ofc as it cost me a bit!!!) it also has a PS3 connector on the console end so can be used with a PS3 as well.
Works fine on my NTSC Wii VC games.
Isn't that 3rd party VGA cable just a component-vga transcoder? Ie, it's not pure VGA output it's just the component signal being turned into a VGA.
Yes but it results in no overscan and doesn't force the crappy post processing the samsung screens do on component signals.
Woah, I'd just about given up on getting my Wii to work on my monitor. (Tried a VGA box and from what I'd heard it was the best option) Guess that was before this cable came along anyway. Many thanks, this is being ordered straight away. :D
