- 7 Dec 2002
- Kent
Basically want to run a minimal XP Pro install on a celly 400/ 256 meg laptop.
Any advice appreciated.
BigBoy said:Makeing an Nlite CD is the best thing you can do mate i make one for every comp i work on it just makes life so much simpler. you can also intergrate drivers and stuff.
UOcUK Poopscoop said:Basically want to run a minimal XP Pro install on a celly 400/ 256 meg laptop.
Any advice appreciated.![]()
Ian said:Is nlite better than http://www.litepc.com/xplite.html ?
BigBoy said:By miles
Also if you can get another 256mb ram for the old beast it will be more than happy.
The only thing realy holding you back will be the harddisk speed. as the transfer rate will be lower than the equivalent(sp?) desktop system.
