I ask this question because I have been trying to work out why I have low gpu usage in Batman ac. I have noticed that the frame rate is the same whether using sli or not.
Both gpu's on use approx 55% and the bench says min 43 and average 80 fps with physx on high. That's the same as result using just one gpu.
I then turn off physx and the gpu usage on both cards goes into the 90's and the frames are 84 min and 180 average.
Battlefield 3 also has it's quirks, giving a similar result when using one or two cards.
Is this normal behavior?
Is my 2500k @ 4.5 to blame?
