29 Oct 2008 at 16:15 #1 Frapple Frapple Soldato Joined 4 Nov 2007 Posts 4,514 Pleh Need to get it out to 14 remote users asap and haven't got time to drive around, a few of them are on 3g/un-accessible by RD. Thanks
29 Oct 2008 at 17:19 #2 Django x2 Django x2 Soldato Joined 28 Sep 2008 Posts 14,222 Location Britain Frapple said: Pleh Need to get it out to 14 remote users asap and haven't got time to drive around, a few of them are on 3g/un-accessible by RD. Thanks Click to expand... Check your update settings in WSUS as its not a critical or security fix you may need to pick it up by altering your classifications. You cant add your own installs to WSUS. If that fails, why not create a folder share that they can browse to?
29 Oct 2008 at 17:26 #3 Frapple Frapple Soldato OP Joined 4 Nov 2007 Posts 4,514 Decided best route will be batch file to do X:/net35.exe /qb /norestart 1 by 1.
29 Oct 2008 at 17:31 #4 Django x2 Django x2 Soldato Joined 28 Sep 2008 Posts 14,222 Location Britain Frapple said: Decided best route will be batch file to do X:/net35.exe /qb /norestart 1 by 1. Click to expand... Stick it in a logon script??
29 Oct 2008 at 17:35 #5 Frapple Frapple Soldato OP Joined 4 Nov 2007 Posts 4,514 Aye have done. Well, made a copy and changed those that need it. Thanks
29 Oct 2008 at 22:27 #6 Nanobot Nanobot Associate Joined 18 Sep 2008 Posts 985 If they can get logon scripts, I would have thought they would be accessible remotely?
30 Oct 2008 at 08:59 #7 Frapple Frapple Soldato OP Joined 4 Nov 2007 Posts 4,514 They've got access, just not enough for 51mb!
