I have an annoying problem on a PC that I am about to hand down to my son.
It has a sporadic start up fault. Sometimes when you press the power up button, the fans spin and that it.
When the system starts normally, the fans spin fast, then quickly slow down and you get a bllep and the bios spalsh screen appears.
When it gets stuck the fans just come on fast - no slow down, no bleep, no bios spash screen.
Power down and on, usually results in the same until after 5 - 10 cycles it starts okay.
I figure it is either the MoBo or the PSU and would be happy to replace either - but can't work out which would be at fault.
My problem in diagnosing is
(1) Only sporadic - more often than not it starts okay
(2) No spare MoBo to try
(3) No spare PSU to try
(4) Inspected the MoBo and the capacitors look fine
Both components are fairly old
Mobo - abit IP35
PSU - Xclio 600W Great Power modular http://www.xclio.com/products/products-psu-great-550w.htm#details
Any idea what I could try to isolate the problem?
Cheers,
Nigel
Mobo - abit IP35
Cheers,
Nigel
