Anyway to unscratch a dvd?
3 Feb 2009
I lent a friend a couple of films and it looks like hes played hockey on the kitchen floor with em. Is there anyway to make em playable again, apart from the toothpaste thing?
A wee bit of Brasso, then wipe in a fast circular motion pressing firmly on it. Wipe clean with a tissue and you're good to go.
Anyway, to answer the question, an optical disc has a layer of film above the surface itself, that is most likely scratched. Buy a disc cleaning tool that scrapes away a fine layer of this film leaving a smooth surface.
http://www.htfr.com/more-info/MR166491
Be careful doing it by hand using cream solutions like brasso etc. You can not always scrape away an even layer all round like a kit machine (above) can and the disc could wobbe when in use or shatter inside the drive.
Never had an issue with toothpaste myself - just don't use one with bits in it. Some of my drives can be pretty picky at times, so it's not uncommon that I have to do a DVD that lovefilm sends me out. From the amount of visible toothpaste in the slight gap between the plastic layers in the centre, other people have similar issues as well with some of the older ones.
Most DVD rental shops do it for a few quid, always done a decent job of it when I've gone in with PS3 and PS2 games in the past.
In the past, I've ripped the contents of a dvd to desktop when it no longer plays (skipping). Might be worth a go
This actually works, I've done it before with an audio disk that won't read direct from the drive, or a proper cd player, due to what was obviously surface damage to the top layer, but bear in mind that very act will label you as a terrorist.
And you will go to hell, and you will burn in fire and brimstone because you are a criminal and you hate the baby jesus.
