aoc 24" monitor power cable replacement..
GOnna give the house a better look through tomorrow..hopefully I find it..I literally disconnected it 2months ago and the power cable should be in my room but its not..illuminati confirmed.
Hi
If you look at the picture of the in this review it shows you what specification of the AC adapter is:)
http://www.kitguru.net/peripherals/monitors/zardon/aoc-g2460pg-g-sync-144hz-1ms-gaming-monitor/2/
On the back of the monitor it says 19v - 3.42a
http://www.aliexpress.com/item/19V-...est=201556_1,201527_1_71_72_73_74_75,201409_5
Reckon this will do, if i cant find it?
Well I sent a message on their facebook of that site, if they could provide me the right size and specs of the adapter, hopefully they reply
yeah even in the manual for the monitor it mentions nothing about the adapter size ect but hopefully you will get a response from them with an answer:)
If you look at this one and compare it to the one you just got does the end fitting look slight different?
http://www.amazon.com/Monitor-Charger-PHILIPS-ADPC1965-ADS-65LSI-19-1/dp/B00UIWNTX0
They saw my message and ignored it, and ye it does, but still dont think it'll work..man what the hell how does my adapter run away from my room ffs -.- life
Why is it this difficult to get a simple adapter -.- *** u aoc
"19 VDC, 3.42 A, plug polarity is + tip - ring." apparently..but cant find it either..
