** AOC 4K BUNDLE DEAL!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
At OcUK not only do we have stock of the amazing AOC 4k monitor we are now giving away a Razer mouse and OcUK mat, check out the freebies:-
Razer Abyssus 3500 DPI Optical Gaming Mouse @ £34.99 inc VAT
The Razer Abyssus is created for gamers looking for quality, reliability and performance in a no-nonsense, straightforward gaming-grade mouse. Designed to focus on the fundamentals of competitive gaming, the Razer Abyssus is armed with ultra-responsive buttons tuned for maximum tactile feedback. With an uncompromising 3500dpi Razer Precision 3.5G infrared sensor at its core, take full control of your every aim with perfect tracking so you outgun your competition.
- 3500dpi Razer Precision 3.5G infrared sensor
- 1000Hz Ultrapolling / 1ms response time
- Mechanical dpi/polling rate switches
- On-The-Fly Sensitivity adjustment
- No Drift Control
- Always-On mode
- Ultra-large non-slip buttons
- 16-bit ultra-wide data path
- 60-120 inches per second and 15g of acceleration
- Three independently programmable Hyperesponse buttons
- Ambidextrous design
- Scroll wheel with 24 individual click positions
- Zero-acoustic Ultraslick Teflon feet
- Seven-foot, lightweight, non-tangle cord
- Approx. size in mm: 115(L) x 63(W) x 40(H)
Only £34.99 inc VAT.
ORDER NOW
OcUK Mega Mat Medium Elite Tactical Gaming Surface @ £9.95 inc VAT
Gaming Dominance: The OcUK Mega Mat Is an all in one tactical input solution.
Engineered to exacting specifications, The OcUK Mega Mat XL Elite Tactical Gaming Surface is a revolution in gaming surface technology.
Featuring the striking Overclockers UK logo, subtly placed on the Surface, your opponents will tremble before you in the knowledge that their system is simply not as fast as yours.
Your desk environment will be transformed, offering you comfort and precision that is unavailable with other, inferior gaming surfaces.
Ground-breaking woven fibre technology and anti-glide resistance coating gives mouse sensors the optimum surface to track on whilst maintaining responsive and uniform tracking capability.
The high grip rubberised base layer provides excellent mechanical grip to the desk surface ensuring that your movements are accurate and that your peripherals are secure.
The OcUK Mega Mat Medium Elite Tactical Gaming Surface is fully compatible with the Official Overclockers UK Elite Gaming Mug. These items can be used in conjunction with each other to achieve ultimate gaming performance.
- Sleek Black design
- 352mm x 255mm x 3mm
- Stunning Overclockers Logo printed on the surface (15cm long)
- Smooth cloth surface
- Rubberised grip base to reduce any movement
- Fully compatible with the Official Overclockers UK Elite Gaming Mug
- Large surface area for increased desk to gaming surface traction
- Spill resistant
- SLI and Crossfire Compatible
- Available in right and left handed configurations
- Compatible with a wide range of hardware configurations
Only £9.95 inc VAT.
ORDER NOW
Here is the amazing monitor!!
AOC U2868PQU 28" 4K 60Hz 1MS Gaming Widescreen LED Monitor - Black @ £499.99 inc VAT
The U2868PQU from AOC is designed for gamers as it features a rapid 1ms response TN panel with a staggering resolution of 3840x2160. Your games will never have looked so good, but bear in mind to play the latest games at 4k resolutions you will need a minimum of 780Ti or 290X and ideally a pair running crossfire/SLI to play at 4k with maximum details with 60fps or more. This monitor is also 60Hz at 3840x2160 when connected via DisplayPort.
Featuring great connectivity with VGA, DVI, HDMI and DisplayPorts along with a full height adjust, pivot and swivel stand with VESA 100x100 support. Making the AOC U2868PQU ideal for eye-finity/surround setups. The monitors also includes stereo speakers and USB Hub as well.
Specification:-
- Size with stand (W x H x D ) : 658.9x560.6x245 (mm)
- Without stand (W x H x D ): 658.9x395.8x50 (mm)
- Display Screen Size: 28" (70.8cm)
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 80,000,000
- Resolution: 3840x2160 (Only over DisplayPort at 60Hz)
- Response Time: 1ms (GTG)
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x HDMI, 1x DisplayPort, 1x DVI, 1x VGA, 1x USB Hub
- Stand: Height adjust, pivot & Swivel
- USB Hub: Yes
- Speakers: Yes
- Warranty: 3yr
Only £499.99 inc VAT.
ORDER NOW
