Having a problem with getting G-menu to work and its really needed as the physical monitor buttons are literally painful to use! It keeps telling me 'monitor not supported' even tho the website says it is.
Support are useless. Ive been emailing AOC and the company that makes G-Menu and im getting nowhere.
Really need to know if anyone else out there with this model has G-menu working? if so what monitor driver did you use? the only one i can find isnt even for this model!
Thanks.
Thanks.
