** AOC FALL MONITOR COLLECTION - PRE ORDER NOW**
OcUK Staff
23 Feb 2015
Overclockers UK HQ
Hi all,
I've listed the new monitors from AOC's Q3 releases. You can find out the info below. The Curved G2 ones are replacements for the older G1 Curved range.
The "U" have height adjustable stands compared to the "AE" but otherwise same panels and specs.
There is a fairly interesting 27" nano IPS I am looking forward to seeing reviews of too (just waiting for URL to generate on that one will update below later when it has)!
Stock should be landing from September onwards.
aoc ag273qxp 27" 2560x1440 nano ips 165hz 1ms freesync premium widescreen led backlit gaming monitor @ £429.95 inc vat https://www.overclockers.co.uk/
display resolution 2560x1440, display size 27", refresh rate 165hz, freesync premium, 1ms response time, contrast ratio 1000:1, panel type nano-ips, height adjust, tilt, swivel, speakers
only £429.95 inc vat.
order now
AOC AG251FZ2E 25" 1920x1080 TN 240Hz 0.5ms FreeSync Premium Widescreen LED Backlit Gaming Monitor @ £308.99 inc VAT https://www.overclockers.co.uk/aoc-...een-led-backlit-gaming-monitor-mo-05k-ao.html
Display Resolution 1920x1080, Display Size 25", Refresh Rate 240HZ, FreeSync Premium, 1ms Response Time, Contrast Ratio 1000:1, Panel Type TN, Tilt, Swivel Height Adjust, Flat Base
Only £308.99 inc VAT.
ORDER NOW
AOC C27G2U/BK 27" 1920x1080 VA 165Hz 1ms FreeSync Premium Curved LED Backlit Widescreen Gaming Monit @ £234.95 inc VAT https://www.overclockers.co.uk/aoc-...acklit-widescreen-gaming-monit-mo-05j-ao.html
Display Resolution , Display Size , Refresh Rate , Sync, Response Time, Contrast Ratio , Panel Type , Curved 1500R, Height Adjust, Tilt, Swivel
Only £234.95 inc VAT.
ORDER NOW
AOC C27G2AE/BK 27" 1920x1080 VA 165Hz 1ms FreeSync Premium Curved Widescreen LED Backlit Gaming Monitor @ £219.95 inc VAT https://www.overclockers.co.uk/aoc-...screen-led-backlit-gaming-moni-mo-05h-ao.html
Display Resolution 1920x1080, Display Size 27", Refresh Rate 165Hz, FreeSync Premium, 1ms Response Time, Contrast Ratio 4000:1, Panel Type VA, Speakers, Tilt, Curved 1500R
Only £219.95 inc VAT.
ORDER NOW
AOC C24G2U/BK 24" 1920x1080 VA 165Hz 1ms FreeSync Premium Curved Adjustable Widescreen LED Backlit G @ £189.95 inc VAT https://www.overclockers.co.uk/aoc-...table-widescreen-led-backlit-g-mo-05g-ao.html
Display Resolution 1920x1080, Display Size 24", Refresh Rate 165Hz, FreeSync Premium, 1ms Response Time, Contrast Ratio , Panel Type VA, Height adjust, Tilt, Swivel
Only £189.95 inc VAT.
ORDER NOW
AOC C24G2AE/BK 24" 1920x1080 VA 165Hz 1ms FreeSync Premium Curved LED Backlit Gaming Monitor @ £164.99 inc VAT https://www.overclockers.co.uk/aoc-...ved-led-backlit-gaming-monitor-mo-05f-ao.html
Display Resolution 1920x1080, Display Size 24", Refresh Rate 165Hz, FreeSync Premium,1ms Response Time, Contrast Ratio 3000:1, Panel Type VA, Speakers
Only £164.99 inc VAT.
ORDER NOW
Looks like it is 0.5ms on AOC's website as well, the typo is the tag. Although it goes without saying that manufacturer quoted response times are basically meaningless at this point.
