- 31 Dec 2015
Hello,
I recently bought this monitor from OCuk, I noticed when I first started using it that it did not feel any smoother than my only monitor when in 144hz (Old one was 60hz). So I did the test on this site http://www.testufo.com/#test=frameskipping and found to be having massive frame skipping issues at 120hz and 144hz. This is how I set it up:
Used the Display Port cable that came with the monitor
then changed the monitor to 144hz in the resolution/properties. The screen recons it is in 144hz but gets lots and lots of skipping.
So I then changed it down to 60hz and it had no skipping at all.
I have defiantly set it up correctly right? do you thing the monitor is faulty?
