AOC G2460PF - Questions/Opinions
6 Oct 2004
Southampton, UK
I have narrowed it down to the above monitor as a potential next purchase.
Currently using a Dell U2414H , however i find it not fast enough to keep up with the game Overwatch.
Anyone use the above screen with Overwatch or other fast paced FPS
I have a RX480 which has Freesync , hence the above screen which will work with it.
Is there any other screens with similar spec that i should consider in the £200-£250 range at all.
Thanks in advance
I'm super pleased with mine.
Fast responsive
Freesync
Uniform backlight
No dead pixels
Very pleased with QC over more expensive models
Poor in built speakers
Red line on bezel
Washed out colours (I use vibrance GUI to give it done saturation for gaming)
Very pleased with mine!
Fast responsive
Freesync
Uniform backlight
No dead pixels
Red line on bezel
Thanks for the info
I dont intend to use the built in speakers.
Im guessing the IQ wont be a patch on my Dell U2414H , but should be ok for gaming right ?
Thanks for the info
Yeah superb for gaming. But I crank my vibrancy up for rich inaccurate colours. In game looks great. Having owned a Benq 144hz before this I upgrade to this purely for freesync which is so worth it. I usually cap in game at around 140fps to stay in range.
I also have one and I'm happy with it, or was until I put another monitor next to it.
The freesync and 144hz are amazing, the colours are not although that doesn't bother me massively.
I have just bought this Monitor and have it connected up to my gaming PC. It is connected via DVI to my graphics card which is a Nvidia 1070.
the problem i have is that when i select the monitor to display in 144hz, the screen has a Green overlay and continues to do this until i change it back to 60hz
any suggestions will be appreciated
