** AOC G2460PQU 144Hz GAMING MONITOR WINS AWARD! ***
11 Dec 2005
Cheshire
Winning the "Worth Buying" award, the AOC G2460PQU 24" 144Hz monitor continues to impress!
"A very capable screen designed to meet the needs of gamers." - KitGuru
Read the full review here
AOC G2460PQU 24" Widescreen 144Hz 1ms Gaming LED Monitor - Gunmetal @ £239.99 inc VAT
This display will make any gaming enthusiast´s heart beat faster: the stylish g2460Pqu will impress you with crystal-clear pictures. Enjoy fast-paced action sequences from the latest games or movies – crisp and blur-free due to an ultra-fast response time of just one millisecond and a refresh rate of 144 Hz. The strong typical contrast (1000:1) and high brightness (350 cd/m²) provide brilliant images. This gamers´ dream-come-true sports numerous connectivity options, such as D-Sub, DVI Dual Link, HDMI, DisplayPort and an integrated USB hub. These enable you to comfortably plug in several devices at the same time and display hi-res content on the large 61 cm (24") screen. Also on board: an integrated USB hub with 4 ports, including a fast-charge USB port for mobile devices. In addition, the Full HD display is equipped with LED backlights, making it particularly economical despite its great performance.
Product Review
- Won Kitguru "Worth Buying" Award
- Full Review Here: http://www.kitguru.net/peripherals/monitors/zardon/aoc-g2460pqu-144hz-24-inch-monitor-review/
Specification:-
- Monitor Size: 24"
- Visible Screen Size: 61 cm
- Screen Format: 16:9
- Brightness: 350 cd/m² (typ)
- Contrast Ratio Dynamic: 80.000.000:1
- Contrast Ratio Typical: 1000:1
- Pixel / Dot / Pitch: 0.276 (H) x 0.276 (V)
- Display Area: 531.36 (H) x 298.89 (V)
- Viewing Angle: 170°/160° (CR 10)
- Response Time: Up to 1 ms GtG
- Maximum Resolution: 1920 x 1080@144 Hz
- Recommend Resolution: 1920 x 1080@144 Hz
- Colors: 16.7 M
- HDCP compatible: yes
- Inputs: Analogue, DVI-D, HDMI & DisplayPort
- Dimensions (WxHxD): 565.4 x 393.6 (+130) x 244.58 mm
- Warranty: 3yr
Only £239.99 inc VAT.
ORDER NOW
"A brand like AOC" I currently have a 27" AOC monitor and it's superb,if it does the job well,i wouldn't mind paying that price,in fact i might just do so.
drop it to 200 quid on a two and i might bite anythings gotta be an improvement for gaming over a basic 60hz sammy
If a manufacturer where to throw a 1920x1080 <3ms >100htz panel on a ~21" and market it below £200 I'm sure they'd be onto a winner...
Until then these 24" panels at 'only' 1920x1080 seem very over priced (due to being 144htz and size) for the resolution... But that's my opinion which is obviously incorrect as there's so many around the same price point (£240-£350) :p ;)
(Note I've a 'cheap' Hanns-G 21" that does 1680x1050 and is 6 years old at work, so 1920x1080 on 21" doesn't seem too far fetched!)
Technically the screen is not ideal for a graphic designer or photo editor. By default the colour curve is out of balance and the screen exhibits a slight blue bias. Even after manual adjustment, the colour curve was never completely accurate. Linearity and uniformity are average for the class, although text clarity and sharpness are very impressive.
