AOC Q2770PQU 27" Widescreen LED Monitor
was going to go for the AOC myself, had it on order elsewhere as OC didnt stock, ended up going for the Iiyama 27" XB2779QS , nice if you get little bleed..Will be interesting to see how the AOC fairs
Yeah that review was posted on the other thread last month, was waiting on a tft central review.
There are at least 2 other reviews on German sites:
http://www.pcwelt.de/produkte/AOC-Q2770PQU-TFT-Bildschirm-Test-8564980.html
http://www.hardwareluxx.de/index.ph...itore/29776-aoc-q2770pqu-im-test.html?start=3
They only measured around 229:1 and 736:1 respectively which is poor.
The measured contrast ratios are wildly different across different reviews suggesting AOC quality control is quite bad so you may as well play the Dell/Ilyama panel lottery as AH-IPS is theoretically better than PLS.
