I am trying to connect my R9 290x to the AOC using the Display port. I can boot up the system if I plug both HDMI, and DP into the same gpu, but if I try to boot the system up with just the DP connected it says "input not support"
has anyone came across this issue before, and hopefully solved it?
Cheers.
Cheers.
