hi all, first time poster, long time lurker...
i have been trying to get onto adsl max with AOL, however my line can only support up to 1mbps, and i am on the GOLD package, i have phoned AOL to ask to be put on the platinum and my line upgraded to the ADSL MAX, but every time i have tried (tried about 7 times) i have been told this is not possible as my line can only support 1mbps, according to the bt broadband checker i can get 2.5mbps ADSL MAX, i have told AOL this but they seem adiment that the checker is wrong and i am stupid, i finnaly managed to nearly get one guy to put the order through manually for ADSL max, but he was giving me sum crap about i would be better off sticking with my current speed, after he put me on hold for 10 mins he finnaly gets back to me to say, that i cannot get ADSL MAX due to being too far away from the exchange, which i find it hard to believe.
MY line stats are the following. LOCAL/REMOTE attenuation. 59.5/31.5 SNR MARGIN 29.0.
so how can i get aol to put me on ADSL max if i can actually get it with my line stats?
according to the line checker -You are approximately 2.35km from the exchange (straight line distance).
also has any1 on AOL that could only get 1mbps been accepted for ADSL MAX from them, and if you have how?
thx for help.
PS.
one of the aol guys also told me allthough the checker says i can get aol at 2.5 mbps the lowest ADSL max can sync at is 2mb, and it wont sync at anything bellow that, so he said the second line support guys said there was no point in going through with it.
thx for help.
PS.
