AOl and Belkin 802.11g Wireless Modem Router F5d7632uk4
18 Oct 2002
Maidenhead
Hi all.
Can anyone tell me if I need to install the AOL software with the above modem/router?
Thanks
Paul
Nope, no need for AOL software. Just be sure to set the MTU on the router to 1400.
Have you bought it yet? Belkin network stuff is pretty crap, so I'd advise against buying Belkin.
Ive got a belkin PCI card and a wireless router on AOL. No you dont need the software but as the guy above says set MTU to 1400, you should be ok.
