AOL VR and vista connection problems
8 Feb 2006
UK
Hey guys just finished building new rig.
My problem is that AOL will not connect. It keeps going to the stage where it checks the password and then stops It then presents an error msg (AC-0000). Internet explorer works perfectly and the rest of the computers on the home network are also working fine. Ive contacted AOL about 10 times with no joy and they honestly dont have a clue.
Any suggestions to the problem would be much appercaited
Patrick.
System spec
Netgear DG834G
AOL Platinum 256kbps
c2d e660
p35 ds3r
2gb 6400
500gb
8600gt
vista 32-bit
Thanks for the quick reply
Yeah one computer is directly connected to the router via a network cable and 4 other computer connect via wireless. There is an connection but it will not connect to the service?
Thanks
