29 Mar 2009 at 13:57 #1 bigG bigG Associate Joined 9 Feb 2003 Posts 263 Hello Does anyone know where i can source replacement motherboards for the Aopen xcube. Mine has just died Thanks
29 Mar 2009 at 14:21 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Only thing I can suggest is contact Aopen direct, any were else may get classed a competitor and against the rules.
29 Mar 2009 at 16:50 #3 bigG bigG Associate OP Joined 9 Feb 2003 Posts 263 Oh do OCUK sell them then?
29 Mar 2009 at 16:53 #4 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Is this of any use: http://www.overclockers.co.uk/showproduct.php?prodid=MB-000-ZT&groupid=701&catid=5&subcat=326 They also have a Gigabyte with the Atom CPU.
29 Mar 2009 at 16:58 #5 bigG bigG Associate OP Joined 9 Feb 2003 Posts 263 RJC said: Is this of any use: http://www.overclockers.co.uk/showproduct.php?prodid=MB-000-ZT&groupid=701&catid=5&subcat=326 They also have a Gigabyte with the Atom CPU. Click to expand... Excellent thanks, didn't know about these. Will they fit in the case ok?
29 Mar 2009 at 17:14 #6 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent They should do, assuming Aopen have not used any special tweaks, ie different connectors or none removable I/O Sheild.
29 Mar 2009 at 20:02 #7 bigG bigG Associate OP Joined 9 Feb 2003 Posts 263 Cheers again i will let you know how i get on
