AOR Monitor 24B3HM
7 Sep 2018
Apologies if this has been asked before. I have just bought a new AOR monitor 24B3HM but I am disappointed at how blurry the text is compared to my old ACER monitor. I've looked at all of the YouTube tutorials but to no avail. I would be most grateful for any advice and help. I am using Windows 10 and my default browser is Firefox 135.0.1 (64bit) which is currently up to date.
Thanks
George
Thanks
George
Was the Acer an FHD monitor as well? Blurry text could be resolution and scaling options, or a bad panel, would be good to provide more details.
24" is toward the end of what I'd want for 1080p, so it is possible your old monitor was just a lot sharper due to being a smaller size, but as said, give us more details please.
Agree with comments. If it is only the text "blurry" then it'll be the scaling options.
Because you are on Win10:
- Click start and type "Scaling"
- You should see "Make text size bigger" on the start menu, so click that
- You have 2 options here. There is a "Make text bigger" at the top, you can drag the marker left or right to change text size.
- Or you can click on the drop down below "Make everything bigger" and try different % values
I suspect this 2nd option is above 100%. So try changing it until you feel the text is easier to read.
