Hi guys,
Quick question, My Aorus Xtreme is currently overclocked and holds 2025 Clock and 5982 memory, haven't touched the voltage, my temps normal hover about 60-70 but do peak at about 75 degrees some times, does this seem a bit high? I have a pretty aggressive fan curve already which keeps the fans 90% at 60 degrees and above.
Plus when my temps do hit 75 degrees the clock will drop down to about 2012-1999 but then goes back up to 2025 when 65-70 degrees. Is this normal?
Cheers Lads!
Cheers Lads!
