Aorus ac300w LED issue
5 Mar 2009
I'm having a little trouble with some RgB lighting that comes with this case. I was hoping someone in would have something similar or may be able to help atleast.
https://www.gigabyte.com/Chassis/GB-AC300W#kf
I have managed to get the RGB lights to work on the bars both top and bottom of the front panel but the logos on the side and on the front don't appear to light. I have doubled checked connections but can't seem to get them to work. I have connected them internally using a molex connector direct from the PSU but it does state in the manual albeit vaguely something about USB to PATA for RGB lighting.
I would have thought the way I have it connected would generate enough juice to power all LEDs.
Thanks in advance
