Aorus AP750GM > CPU cable advice
30 Nov 2023
Hertfordshire
Hi all,
I wouldn't normally ask but...I stumped on this one. I'm sure this should be easy and Google'able but I have failed so I'm hoping one of you guys could help
I have a Gigabyte Aorus AP750GM PSU and now have a Gigabyte X670E Master motherboard. So I need a CPU/EPS 4+4 pin cable. But I can't find the correct cable anywhere, well not for my PSU anyway.
There is something like this for a Corsair PSU: https://www.amazon.co.uk/COMeap-Detachable-EPS-12V-Motherboard-Adapter/dp/B07VF887KN
However I don't think this is compatible with my PSU :(
Would anyone be able to point me in the right direction. Even the best place to ask? I have tried Gigabyte support but they don't seem that quick in getting back.
Thank you,
Chris
Yeah I guess so, I've looked everywhere. I will keep looking online.
Unfortunately Gigabyte PSUs aren't very common, you can get Corsair cables (new or used) pretty much everywhere and when I checked the custom makers, they don't even have Gigabyte listed. If you could find another PSU from the same oem, that's sometimes a possibility (depends on the pinout), but in this case, I don't know any other manufacturer who uses MEIC.
Hey guys, thanks very much for your replies. What a mare I never saw this coming. After years of having random cables coming out of my ar5e, I must have accidentally binned my 2 x 8pin cables for this PSU. Gigabyte didn't get back to me, from your replies it kinda confirmed what I thought, these cables aren't easily available as spares to buy.
So I probably just broke every builders rule in the book (cover your ears) and 'adjusted' my spare PCIe 8 pin cables. The 12v / GND pinouts for what I needed compared to PCIe just meant swapping one cable with another. It worked anyway, I'm going to close the case and pretend that never happened.
Thanks again!
:o Yikes. Well, if it works, it works, I guess. :D
