Hi guys, i'm wondering if anyone here would have any idea what i could try next, other than throwing the computer out of the window....3 weeks of messing about with it and its got to that point... : /
The build is,
I9 9900k
AORUS 2080 SUPER max temp ive seen is 72 degrees
AORUS Z390 WI FI PRO....with the latest Bios F12c.
AORUS 4x8GB DDR4 3200mhz Memory
AORUS M2 NVMe 512 drive
AORUS AIO Water cooler 360mm max temp 70 degrees under full load, no overclock.[not been able to get that far yet}
AORUS C300 MID ATX CASE
AORUS K9 Keyboard
AORUS M5 Mouse
Corsair HX 850 psu
Windows 10 Pro 64 Version 1909.
All drivers are up to date from the Gigabyte website and all windows update are done.
It's a new build, all parts bought in the last 6 weeks, but i've had nothing but issues with it. Temps are fine, but it's constantly crashing when I load up a game,it freezes,hangs for ages then restarts...sometimes its ok for an hour no issue, sometimes its straight away.
I get no issues while bench marking with anything i've tried from intelburntest to 3d mark and many more, its just when games start loading up and are about to start...
Things i've tried are...
I've replaced the PSU as that was my first suspect but the same thing is happening with the replacement.
Reinstalled windows twice.
Tried 2 different versions of RGB Fusion.
Ran Memtest86 for 3 loops about 90 mins or so, no errors.
The only info i get from the event viewer is
- System
- Provider [ Name] SMBCtrl - EventID 1 [ Qualifiers] 0 Level 3 Task 0 Keywords 0x80000000000000 - TimeCreated [ SystemTime] 2020-05-05T19:31:16.837626700Z EventRecordID 1382 Channel Application Computer DESKTOP-IPHOB52 Security
- EventData
[err_519]: mcuAddr = 0xcd, offset = 0xed, Word_Read fail
I've ordered some Aorus 3600mhz ram but don't think thats the issue, should be here in the next few days and have an rma arranged for next week with the gpu to test it, as i have a week left of the 30 days after purchase,if its stable with the new ram I will cancel that,but i've been warned with lockdown, it will be quite a long turn around.
I think it's either the GPU or something to do with RGB fusion or the AORUS engine...as the lights freeze just before the crash and on the restart they are all over the place.
I've contacted Gigabyte support but theres been no response, so either they are still in lock down or dont want to touch the issue with a bargepole.
All i know is i've got an expensive toaster sat in front of me that i can basically read emails on and surf youtube....and that i'm really really regretting buying it at the moment... I saved for a very long time to build this and it's not something I could afford to build every year.
This is my first Gigabyte build, i've always gone Asus and MSI for everything.. so i'm hoping its just something ive missed..
If anyone has any helpful advice i'm all ears, thanks in advance.
The build is,
I9 9900k
AORUS K9 Keyboard
AORUS M5 Mouse
Corsair HX 850 psu
- System
- EventData
