AORUS ENGINE Question
17 Mar 2018
Hello, so I was using Aorus Engine for quite some time as all my components (motherboard/ram/aio/gpu) are the same brand.
For some reason I had to uninstall aorus engine for a couple of days but the components kept their settings/colors etc.
Suddenly after a boot my AIO screen shows 00c temperature even if it recognizes and shows my cpu.
I re installed Aorus engine but the issue still remains and also when I try to change pump speed / fans speed etc, everything is dead it doesn't respond to any change. It doesn't even recognize the name of the aio (it used to say AORUS LIQUID 360 or something like that, now it says CPU COOLER)
Any ideas about what has happened please?
EDIT: RGB Fusion (that comes with Aorus Engine) works perfectly it takes all changes in all of the components
I regularly have problems with Aurous Engine! I’m constantly having to uninstall just to even open the software - it’s full of bugs and sorry to say not we’ll designed.
