AORUS GeForce RTX™ 3080 MASTER 10G (rev. 2.0) Help updating Bios and Firmware?
13 Jun 2007
Dorset
Hi. Just installed a GeForce RTX™ 3080 GAMING OC WATERFORCE WB 10G.
I am tring to update the BIOS and Firmeware. In the instrustions it states.
Silent BIOS:
1. Switch the BIOS switch to the Silent side before booting
2. Run NxxA.Fxx.exe
3. Restart system to complete BIOS update
"Switch the BIOS switch to the Silent side before booting". Where is this switch?
Silent BIOS:
2. Run NxxA.Fxx.exe
Scroll down to the dual bios bit
Thanks but unless I misreading it. It just states...
DUAL BIOS
The graphics card provides two BIOSs. OC mode is the factory default setting, which boosts the core clock to 1800 MHz. Standard mode will set the core clock to 1710 MHz.
* Mode switching needs to be rebooted to take effect.
It does not tell how to switch?
15 second google shows the bios switch......
DUAL BIOS
Theres clearly as switch there in the pic move it to left or right by the looks of it for standard or oc mode.
DUAL BIOS
Look which side the switch is mostly on at default it looks like it will be on OC
Just switch it to standard which I'm guessing is the silent
The bit is sticking out you just move it
I see would suggest to contact gigabyte for instructions , poor of them not to give any instructions on rev 2.0 dont see any bios listed on the 2.0 rev page
Yes if only it was on my GPU! I don't think the images are accurate. This is the version I have... https://www.gigabyte.com/Graphics-Card/GV-N3080AORUSX-W-10GD-rev-20#kf
... and these images bare no relation to the physical item shipped at least where the switch is concerned.
There is no firmware update for the gpu you linked its default bios.
you have rev 2.0 so should have newer one and no bios update available, last one for rev 1.0 was to enable Resizable BAR Support you could actually check if you have Resizable BAR working if have motherboard that supports it
