Aorus Master X570 errors
You will need to update the bios on yhe motherboard for the cpu to work. You can do this by using the bios flashback feature
Q-Flash Plus allows you to update the BIOS when your system is off (S5 shutdown state). Save the latest BIOS on a USB thumb drive and plug it into the dedicated port, and then you can now flash the BIOS automatically by simply pressing the Q-Flash Plusbutton.
Check your motherboard manual
I can't even get my PC to bios can I still do this without it?
I have change my original post it's called q flash plus
Check the motherboard manual
Just another quick one in the video it says to only have the motherboard and CPU header plugged it, is this a must because mine all done and if I can't avoid taking off the CPU and re pasting it that would be handy
I'm afraid you'll need to remove the CPU from it's socket - there's a section in the manual that states:
Q-Flash Plus will update the main BIOS only if run without the CPU installed. The system will shut down upon completion.
