Aorus PSU
1 Dec 2015
Those cables look terrible with all those capacitors sticking out like that. That alone would put me off ever buying one of these.
dont think there are a lot of OEMs now doing this, only on a few high end models which made cable sleeve kits a grey area . Should reduce EMI but might of been a bit of an overkill feature or plug in extensions like Lian Li strimer shouldn't get any interference .
kills the look but guessing adds the thought of 10 year warranty
Kills the look but guessing adds the thought of 10 year warranty
Reads like this will be addressed on next production run:
Quote said:
Note the small solid polymer capacitors wired into the ends of the main power cables to help filter out any residual AC ripple and noise. Normally these are sleeved to the cable bundle and in fact Gigabyte informed us this will probably be done during the next production run.
