Hi,
I bought an X7 v2 (http://www.overclockers.co.uk/showproduct.php?prodid=LT-000-AU) from here a few months back. Have barely used it since I picked up a MacBook Pro in the meantime, but just now I was setting the AORUS up for my girlfriend and it's driving me nuts.
It came pre-loaded with Windows 8.1 and every time I would start it up the fan would kick into over drive, really really loud. I checked on the task manager and a bunch of weird Windows applications were running taking up 40% CPU. Checked online and tried to find ways to disable them, but it seemed every time I did something else came up.
Figured I'd do a fresh format and have just finished setting it up now and all the bloatware crap is no longer there, however at idle the CPU is still around the high 50s or low 60s (this seems really high to me) and whenever I use an application (for example Firefox) it will jump to 70c+ and the fans kick in.
Honestly at this point I'm pretty ****ed. Spent £1,700 for this and it's a bit of a joke. Not to be trolling on Windows laptops (I'm a hardcore Windows desktop user) but these laptops are a freakin' joke compared to Macs. Everything about them is crappier. Don't even get me started on the touch pad quality on this thing!
So long story short, anyone got some advice on how not to have my laptop sounding like a vacuum cleaner every time it's running? Is this some sort of hardware fault to have the CPU so hot?
Any advice or comments appreciated as usual. Thank you
