Aorus X7 v2 or Alienware 18
16 Oct 2005
Poole
Aorus specs can be found here: http://www.overclockers.co.uk/showproduct.php?prodid=LT-000-AU
Alienware specs are:
Base Alienware 18 BTX Base Mod
Operating System Windows® 8 PRO (64 BIT) English
Memory 32GB Dual Channel DDR3L at 1600MHz
Keyboard Internal UK/Irish (QWERTY) Keyboard
Video Card Dual NVIDIA GeForce GTX 780M with 4GB GDDR5 - NVIDIA SLI Enabled
Driver 5G WiFi Broadcom 4352 802.11n/ac and Bluetooth 4.0
Hard Drive 2 x 750GB /7200 RPM +64GB SSD
CD ROM/DVD ROM 5X Blu-Ray Disc (DVD+/-RW + BD-ROM)
Wireless Broadcom 4352 802.11 ac 2x2 and Bluetooth 4.0
Cable UK 250V Power Cord
Primary Battery 8-cell Lithium Ion (86 wHr) Battery
Processor Intel® Core™ i7-4900MQ (8MB Cache, up to 4.00GHz, Overclocked)
Color Choice Anodized Aluminum
Avatar Alienware Avatar -Alienhead 3D
LCD 18.4 inch (467.36mm) WLED FHD (1920 X 1080) TrueLife Display
Power Supply 330W A/C Adapter
The Alienware is a bit more expensive, but I've had a good year at work so I'm looking to treat myself. Thoughts appreciated :)
Thanks.
Wait for the 970/980 announcements this week before doing anything.
Thanks, I may just do that :)
Correct me if I'm wrong though, but am I correct in thinking that despite the Alienware I have mentioned being over a year old now it is still one of the best gaming laptops available unless you look to spend £2,500+ on a custom GTX 880m SLI with a newer CPU?
