- 19 Sep 2019
I've just bought myself a Cooler Master H500. From the reviews it says you can plug the 2 200mm LED RGB fans straight into the motherboard for software control rather than using the controller and loosing the reset switch.
Being a complete noob with this I either think I'm doing something wrong or the Aorus Z370 does not have a RGB fan header.
I can see a 4 pin RGBW/RGB LED Strip Header. If I connect the fans 4 pin to this no LED's light up on the fans.
Just below the 4 pin RGBW/RGB Strip header is a 3 pin Digital LED Strip Header but the fans plug is a 4 pin.
Am I correct in assuming that the 4 pin RGBW/RGB header on the board is exclusively for LED strips and cannot be used to control the 200mm fans lighting?
Currently I'm using the included controller with the sata power connection with the loss of my reset switch.
Am I missing something here?
Thank you
Thank you
