Hi,
I'll get right to it, I'm looking to have a set up as follows, wireless router in building A, signal can be picked up in building B but only at the wrong end. I'm looking to use a AP in client mode at the end of building B that gets the signal and then run a wire to the computer. I had a D-link DWL-2100AP in a drawer and while it works fine without encryption but the network i need to join is running WPA/2 and the d-link just doesn't seem to play ball.
Is there a way to make it work? Or is there another AP that people know and have had working? Or is it, from what i've read, like WDS and can't be used with WPA?
Thanks in advance for the help!
Alex
Alex
