I've been running a APC Smart-UPS for a while but I've only just noticed that the output voltage is set to 230V. Looking at the stats for the input voltage it says 249.1 VAC (which sounds a bit high).
Anyone know what I should be using, or have any experience of configuring these? From looking at the options for output voltage on "Line Transfer" it says I can choose 220, 230 or 240V. Intuitively it sounds like it should be set to 240V, but my PC & equipment has been running fine for months as it is?
Some relevant output:
Code:
Input Voltage : 249.1 VAC Operating Frequency : 50.00 Hz
Output Voltage : 249.1 VAC Internal Temperature: 031.0 C
Load Power : 011.7 % Watts Battery Voltage : 27.40 VDC
Max Line Voltage : 249.1 VAC Battery Capacity : 100.0 %
Min Line Voltage : 246.2 VAC Runtime Remaining : 0103 min
Code:
UPS Name : VORNIZ Battery Date : 01/11/05
Output Voltage : 230 VAC Shutdown Delay : 090 sec
High Transfer : 253 VAC Return Delay : 000 sec
Low Transfer : 208 VAC Low-Battery Duration : 002 min
