APC UPS power useage question
16 Sep 2009
Loogabarooga
Does anyone know what the cost of running an APC 1000 UPS would be per year? I have aquired one and would like to start using it to protect my desktop PC and NAS.
Once the batteries charge, not a lot. It doesn't actually quote the input power.
Though for a rough estimate, the thermal output (power wasted as heat by internal electronics) is 100 BTU/hr, (equates to about 30Wh). Given we're not accounting for all the input power using the upper end of leccy prices @ 13p/kWh, about 10p per day if it's fully loaded.
You can get a better estimate if you can get hold of one and look at the input power rating and subtract 675W from it.
I have an APC smart UPS that was drawing 50W even when the batteries were charged and the server was turned off ? not sure if there is a fault with it or normal?
