Hi Guys,
I'm an Aperture 3 user. My main machine is a 2009 iMac, although I've recently picked up a 2012 retina MacBook Pro as a secondary machine, and to do the majority of my photo editing.
The iMac will continue to be my 'main' machine mainly due to the large screen and plentiful storage in contrast to the MBP (500GB hard disk, with a 2TB drive attached via USB for TimeMachine). However, I would like to use the MBP more for my photography...
How do people maintain a single Aperture (or iPhoto) library across multiple machines?
As far as I can tell there are the following options:
1) Store Aperture library on a network attached disk, so both machines can access via the network - although potentially at a loss in performance due to network latency...
2) Store Aperture library on the iMac hard disk, and set up disk sharing to allow access to the iMac's hard disk and Aperture library - easier workflow although eligible for potential library database corruptions/inconsistencies.... as I found out tonight.
I accessed the iMac library via my MBP and imported some new photo's, unfortunately without realising Aperture was already 'open' in my sleeping iMac. This seemed to cause some kind of read/write permissions inconsistency, resulting in a rebuild of the database....
3) Operate two Aperture libraries, a 'master' on the iMac and a secondary library on the MBP. Using the MBP to import photos, I can then do my edits and export the 'project' I'm working on as a new library. I would then drag/drop the new library onto the iMac and merge into the existing library whenever the opportunity strikes.... An Apple suggested approach, but a little 'messy' if I'm honest.
I've tried option 2 and 3, with option 2 being favoured until tonight.
Looking for any further suggestions/ideas based on your own workflow, thanks!
