- 11 Jun 2008
http://www.overclockers.co.uk/showproduct.php?prodid=CB-004-OK
Reviewed here
I'm looking for a micro ATX case 'cause I need to be able to carry my computer around. It doesn't have to be as small as this one but I was wondering if the cooling on the X-QPack2 would be sufficient for:
Core 2 Q9450
GeForce 8800GT
2 x 2GB 1066 (or 800) RAM
1 x HDD, 1 x Optical
I won't be overclocking (not yet at least), I just need to know if there is enough cooling here for the components to run at stock speed. Originally I had been looking at the Apevia X-QBoii, but it seems no one will deliver it to the UK.
Potentially it looks like there's space to drill some holes and add a protruding 120mm fan on the side... not sure if this would compromise stability though. I'm not too concerned about noise if it means I can use this case with these components - something this portable really suits my needs - and it looks awesome!
Reviewed here
Core 2 Q9450
GeForce 8800GT
