Apogee Drive 2
12 Mar 2013
Macclesfield
Can someone help me source one of these in the UK? as long as its in the rules!
im on a budget so dont really want to get one shipped from the US.
Thanks
OK thanks I think, I did kind of use that Google thing, but unfortunately no where seems to have any complete 1155 socket and pump combos in stock, I'm just after peoples advice on where else to look, where to buy used etc.
It doesn't look like above said company or anywhere else will getting anymore in for a while, I have emailed multiple company's with no luck or no reply.
I was looking at buying 1 the other day , You can only get the block , and seperate version for a 1155 now . The place that was just mentioned is the only shop in the country that stocks them , and they only have 1 in stock . They have been out of stock of the DDC pumps , but they came back in on the 15th , but according to one of the swaftech reps any MCP pump will also fit .They have got them on fleabay but are about £25 delivery .
Yeah ive seen them, but i wanted to get the combo you see.
I dont really trust ebay, never mind buying computer components from there!
The search continues for now, but i am already checking out replacements
You will be hard pushed to find the combo mate to be honest mate . As far as I no they have had 1 in stock for about 5 months no , and they guy I spoke to didn't sound very confident of them getting more in . I think you can use the 2011 version you will just need to buy or use a backplate . I'm debating to buy it just to be sure I have got one for a future build . But now with the Swiftech AIO coming out , which is basically what the drive 2 is only with a rad . I might hold off . That's another reason to buy it now with the AIO being released the drive 2 will more than likely be discontinued .
