Are these monitors any good for gaming? And would it be a better choice than the Dell U2410?
they use the same panel, the Apple cinema diasplay is LED backlit instead the U2410 is CCFL lit.
Mind you, the Apple Cinema Display only has DisplayPort as a video inout and it doesn't have any On Sreen Setup Menu, so no way you can set contrast/color presets, scaling etc.
You can always adjust that stuff with the graphics card control panel.
