apple powerbook g4 17" (vga) question
11 Jun 2004
hi i recently bought a 32" sharp lcd (LC-32X20E), which has a lot of different interfacing options one of which is a vga input. i was wondering EXACTLY what i would need to connect my laptop...
i believe apple supply a DVI-VGA adapter so do i just need a VGA lead with male/female settings?
is there any other advice or a better way to get the best quality?
any experienced people if you can share your trials i would appreciate it!
thanks
If you have a spare HDMI port, you'd probably be better off picking up a DVI-HDMI cable and using that.
As for VGA, a male-to-male cable is what you'd be after.
